I have created a survey form in Survey123 Connect that had several "required" fields before it was published. After publishing and collecting data which generated a new feature layer, however, I found that in the field settings in AGOL the settings allow null values. I don't think I would have noticed -- the form works properly and doesn't permit a survey to close without a value in the required fields -- but I also have a Data Interoperability workflow (FME Workbench) in which I have a Writer that uses one of these fields for an upsert feature operation -- but because the field setting is "allow null values" it won't work.
I've tried republishing the survey and nothing changes.
Thanks in advance!
Solved! Go to Solution.
It seems to be expect/designed behaviour, and this explanation makes perfect sense.
https://community.esri.com/t5/arcgis-survey123-questions/required-fields-in-survey-form-still-allow-...
For the feature layer on ArcGIS online, the required question has the setting nullable:"true" by-design, this is because sometimes the required question is used as a relevant question, and when it is not relevant, the required question should be hidden and allowed to submit as null.
