JavaScript XMLHTTP Post
1975
05-04-2023 01:00 PM
JohnLucotch2
Can Survey 123 support XMLHTTP Post?
Thanks
ZacharySutherby
Hello @JohnLucotch2
You can send a POST request using xmlhttp in a custom JavaScript function. The important thing to note is asynchronous calls are not supported so you will need to set the async parameter to false when making the request.
Thank you,
Zach
ZacharySutherby
Hello @JohnLucotch2
Thank you,
Zach
JohnLucotch2
Thanks that is what I was missing.
BigLouC
Any chance you can share the code you are using. I am having a hard time achieving the same and have no luck finding samples. Thanks.
BigLouC
I get all that teach a man to fish, but for those of us in a bind, here is the code:
function settime(objectid, schedulechange, mtoken){
let layerURL = `https://services.arcgis.com/`;
let formParams = `f=json&rollbackOnFailure=true&token=`+ mtoken +`&features={
"attributes": {
"OBJECTID":` + objectid + `,
"Instructions":` + schedulechange + `
let http = new XMLHttpRequest();
http.open("POST", layerURL, false);
//Send the proper header information along with the request
http.setRequestHeader("Content-type", "application/x-www-form-urlencoded; charset=UTF-8");
//Call a function when the state changes.
http.onreadystatechange = function() {
if (http.readyState == 4 && http.status == 200) {
console.log(http.responseText);
http.send(formParams)
console.log("Layer done");
