Issues with Select_one questions
2616
03-24-2020 12:06 PM
JulesKarasira
I created a survey123 with select_one questions. I need a help on how to create the survey;... so that when one choice is picked from any of the select_one questions, the rest of the choices have 0 values (recorded with 0) in the survey data. What statement should I use @Philip.Wilson-esristaff . Your help is appreciated as always.
IsmaelChivite
Esri Notable Contributor
You could go with something like this if you want to submit data for all students in one shot:
This will create a layer for the class, and a related table for students. Use the plus button in the repeat to add data for the next student.
When using a repeat, you can even use aggregate functions. For example, you can get the max, min, average of the weight, height and scores for the class. More info at: Repeats—Survey123 for ArcGIS | Documentation
Using relevant statements to hide/show questions will not work in your case because when a question is not relevant Survey123 will always send null values for it.
Jim-Moore
Hi Jules
Could you please provide your XLSForm and a bit more detail (perhaps as an example) on what you're hoping to achieve? You can attach files to your post using the 'advanced editor'.
Thank you,
Jim
JulesKarasira
Below is what I am trying to do. I want the question "Student information details" to popup every time I click on each student's name instead of below all students' names.
Once I submit survey all students' information is sent at once.
JulesKarasira
Bellow is the sample file
IsmaelChivite
JulesKarasira
Thanks a lot Ismael Chivite‌, this was so helpful.
I appreciate!
