Issues creating a report template using a table format
557
07-31-2025 06:29 AM
TimWeisbrod
This is my first time trying to create a report template.  I am not sure how to fix this error and I am looking for suggestions on that.  I used the downloadable report template to provide syntax to insert into the following table, I keep getting the same error (Error: An error occurred when checking the report template. Failed to parse $(XXXayla_3_sample_is_taken_to) since XXXayla_3_sample_is_taken_to cannot be found in the current parsing scope.).
LOG OF TEST PIT NUMBER - ${hole_number_and_depth}
 OWNER: ${owner}
SURFACE / HOLE TOP ELEVATION: ${surface_elevation_feet}
FLOOD PRONE AREA: ${flood_prone_areas}
 COUNTY: ${county}
 PRACTICE: ${practice}
PERCHED WATERTABLE ELEVATION: ${perched_water_table_elevation_f}
TOP OF PERCHING LAYER ELEVATION: ${top_of_low_permeability_perchin}
 LAT/LONG: ${lat_long}, ${type_in_latitude_longitude | appearance:"multiline"}
 EQUIPMENT: ${equipment}
SEASONAL HIGH WATER TABLE ELEV. : ${seasonal_high_water_table_eleva} WETLANDS NEAR SITE: ${wetlands_near_the_site}
LANDSCAPE POSITION: ${landscape_position}
SOIL MAP UNIT: ${soil_map_unit}
 LOGGED BY: ${logged_by}
OBSERVED SUBSURFACE SATURATION ELEV. :${observed_significant_subsurface}
OBSERVEDFREE” WATER ELEVATION: ${observed_free_water_elevation_f}
NATIONAL MAP BEDROCK: ${national_bedrock_geology}
BEDROCK ENCOUNTERED: ${predominate_bedrock_type_encoun}
 DATE: ${date_and_time}
TOP OF WEATHERED BEDROCK ELEVATION: ${top_of_weathered_bedrock_elevat}
TOP OF COMPETENT BEDROCK ELEVATION: ${depth_to_competent_bedrock_feet}
KARST TYPE - NATIONAL MAP: ${united_states_karst_map}
KARST FEATURES WITHIN 1000 FT: ${are_there_karst_features_sinkho}
DEPTH
USCS
GRADATION
PLASTICITY
MUNSELL COLOR AND %
MOISTURE
STRUCTURE
GEOLOGY
ADDITIONAL COMMENTS
SAMPLES
FROM
TO
SYMBOL
GROUP NAME
% B
% C
% G
% S
% FINE
Non, Slightly, Low, Medium, High.
MATRIX
REDOX.
Dry, Slightly Moist, Moist, Very Moist, Wet.
Stratified, Laminated, Fissured, Slicken-sided, Blocky, Pris- matic, Lensed, Massive.
Alluvium, Slope Alluvium, Colluvium, Glacial Till,
Glacial Lake Sediment, Outwash, Residuum, Loess, Bedrock.
Dilatancy: None, Slow, Rapid; Odor (mention if unusual); Consistency (Mention if very soft or soft in wet condition); Location of Seepage and Other Items such as caving or sloughing of pit and how the water enters the pit; Description of lenses and / or mixed materials encountered.
FROM
TO
(FT.)
(FT.)
(i.e-ML)
(i.e.-Silt w/Sand)
>12"
3"-12"
3"-1/4"
1/4"-#200
<#200
(90% 10YR 4/4)
(10% 10YR 5/2)
(FT)
(FT)
${beginning_depth_of_layer_1_in_f}
${ending_depth_of_layer_1_in_feet}
${layer_1_unified_soil_classifica}
${layer_1_full_uscs_group_name_wi}
${layer_1_boulders}
${layer_1_cobbles}
${layer_1_gravel}
${layer_1_sand}
${layer_1_fines_200_sieve}
${plasticity_pi_of_layer_1}
${layer_1_matrix_color_percent_of}%
${field_129}
${layer_1_concentrated_redoximorp}
${field_75}%
${layer_1_reduced_redoximorphic_f}%
${field_78}
${layer_1_moisture_estimate}
${layer_1_soil_structure}
${geology_of_layer_1}
${field_10 | appearance:"multiline"}
${layer_1_sample_is_taken_from}
${layer_1_sample_is_taken_to}
${layer_1_sample_name}
${beginning_depth_of_layer_2_in_f}
${ending_depth_of_layer_2_in_feet}
${layer_2_unified_soil_classifica}
${layer_2_full_uscs_group_name_wi}
${layer_2_boulders}
${layer_2_cobbles}
${layer_2_gravel}
${layer_2_sand}
${layer_2_fines_200_sieve}
${plasticity_pi_of_layer_2}
${layer_2_matrix_color_percent_of}%
${layer_2_soil_matrix_munsell_col}
${layer_2_concentrated_redoximorp}%
${field_114}
${layer_2_reduced_redoximorphic_f}%
${field_112}
${layer_2_moisture_estimate}
${layer_2_soil_structure}
${geology_of_layer_2}
${additional_comments_about_layer | appearance:"multiline"}
${layer_2_sample_is_taken_from}
${field_104}
${layer_2_sample_name}
${beginning_depth_of_layer_3_in_f}
${ending_depth_of_layer_3_in_feet}
${layer_3_unified_soil_classifica}
${layer_3_full_uscs_group_name_wi}
${layer_3_boulders}
${layer_3_cobbles}
${layer_3_gravel}
${layer_3_sand}
${layer_3_fines_200_sieve}
${plasticity_pi_of_layer_3}
${layer_3_matrix_color_percent_of}%
${layer_3_soil_matrix_munsell_col}
${layer_3_concentrated_redoximorp}%
${field_143}
${layer_3_reduced_redoximorphic_f}%
${field_141}
${layer_3_moisture_estimate}
${layer_3_soil_structure}
${geology_of_layer_3}
${field_135 | appearance:”multiline”}
${layer_3_sample_is_taken_from}
${ayla_3_sample_is_taken_to}
${ayla_3_sample_name}
${beginning_depth_of_layer_4_in_f}
${ending_depth_of_layer_4_in_feet}
${layer_4_unified_soil_classifica}
${layer_4_full_uscs_group_name_wi}
${ayla_4_boulders}
${ayla_4_cobbles}
${layer_4_gravel}
${layer_4_sand}
${layer_4_fines_200_sieve}
${plasticity_pi_of_layer_4}
${layer_4_matrix_color_percent_of}%
${layer_4_soil_matrix_munsell_col}
${field_169}
${layer_4_concentrated_redoximorp}
${field_167}
${layer_4_reduced_redoximorphic_f}
${layer_4_moisture_estimate}
${layer_4_soil_structure}
${geology_of_layer_4}
${field_163 | appearance:"multiline"}
${layer_4_sample_is_taken_from}
${layer_4_sample_is_taken_to}
${layer_4_sample_name}
General Comments: ${general_comments | appearance:"multiline"}
BORING DEPTH:${depth_to_the_end_of_the_boring} ELEV. :${elevation_of_the_end_of_the_bor} REFUSAL TYPE: ${reason_for_ending_the_boring}
DISCLAIMER: ALL SOIL CLASSIFICATIONS FIELD CHECKED. IF CONCLUSIVE SOIL CLASSIFICATION RESULTS ARE REQUIRED FOR ENGINEERING PURPOSES THEN SEND A SAMPLE OF IT TO THE LAB.
TylerGraham2
What that is saying is it can't find a matching field in the layer to pull data from. This can happen a couple of ways.
First, make sure the field name matches exactly, for example if you have a field "Location" and in the template call ${location} you'll get the error. Looking at your table is the "ayla" part of the name supposed to be "layer"?
Make sure you're using squiggly brackets {} and not parenthesis () when calling fields in the template.
Also, if the field is in a repeat and you call it outside of the repeat table/layer you'll get the error. If you have a repeat called "locations" with a field named "Location" you need to open and close the repeat table.
${#locations}
{Location}
Conversely if you opened a repeat and forgot to close it with the ${/} you'll get the error.
And finally, sometimes it just hates you. I've found that if you open repeats or if statements in a table it gets really finicky throws that error because it doesn't like that you used a Word header style to open it and closed it with the formatting set as a body style.
