Issue with select_one autocomplete in repeat
2636
05-09-2017 05:42 AM
JamieKelly1
I have a select_one question with an appearance of autocomplete inside of a repeat.  When I click the plus  button to add a new item in the repeat, the select_one question is not cleared.  I have other questions in the repeat that are cleared (ready for new input), but the select_one with the autocomplete appearance still contains the value from the before adding the new item.  Shouldn't it also clear so that it is ready for the new information?
Before and After Adding
JohnathanHasthorpe
Hi Aaron - yes this has been resolved
JohnathanHasthorpe
Hi Jamie - this is a known bug. Autocomplete does not currently work within a repeat. We are working on a resolution and will update you all on this forum when this is available.
Thanks
John
AaronNepple1
John,
Just wanted to check in on this bug. We are currently building a form that would be using autocomplete within a repeating question.
Has this been resolved?
Aaron
JohnathanHasthorpe
