Issue with relevant statement - 2 questions appear, only want one based on previous answer
2438
7
05-16-2023 06:27 AM
dwold
I have the following relevant statements set up below but when certain selections are made both answer options are available. I only want one based on the value of a previous statement. What am I doing wrong? I've selected Unemployment which is over 1000 but the question for under 1000 also appears.
I've tried both:
${target_set} > 1000 or ${un_target_set} > 1000
(${target_set} > 1000) or (${un_target_set} > 1000)
DougBrowning
MVP Esteemed Contributor
Yes just like I thought a calculate defualts to string.  Set the bind::type to int on those and that should do it.
The other newer way to do it is to set to type integer then use the hidden apperance.
jcarlson
If you want only one question to show up consistently, you need conditions that don't overlap at all. Will there ever be answers to both target_set and un_target_set?
- Josh Carlson
Kendall County GIS
dwold
@jcarlson It will be one or the other. target_set and un_target_set are pulling values from different csv files but all un_target_set values are > 1000 so I want the user to enter in a % when that is the case (unemployment is selected). Also, if target_set is > 1000 the user should enter a % value but not have the option for entering a value
dwold
@jcarlson would it be best to split up the two relevant statements to make three? However, I am trying to not create more fields in the feature layer
type=integer name=target_value_percent relevant=${target_set} > 1000
type=integer name=target_value_numeric relevant=${target_set} < 999
type=integer name=un_target_value_percent relevant=${un_target_set} > 1000
DougBrowning
I do not see the fields target_set or un_target_set in your form at all.  Is it just not shown?  Can you post the whole form.  My guess would be those are note fields so they count as sting not int.  You can set the bind type column to int to fix that.
dwold
@DougBrowning those fields are calc fields from a csv file and then used to display a Standardized Target Statement note. Based on the value in the target statement, I want the user to enter in a either a value (<1000) or a percentage (> 1000)
 The action I am looking for behaves correctly when I do not have or ${un_target_set} > 1000 in the relevant field but those values (un_target_set) are all over 1000 so I want the user to enter in a percentage when they select unemployment from a previous question.
DougBrowning
dwold
I think I got it to work...might not be the best/most efficient but I added ${un_target_set} < 1000 to the second statement and that question is gone when unemployment is selected because there are no values under 1000
