I'm transferring an old MS Access database to Survey123. I'm currently creating choice lists and configuring the survey before I import in the historic data.
I noticed that in the Access database, most of the fields were associated with lookup tables. For example, "m", "f", and "u" were stored in the database instead of "Male", "Female", and "Unknown". If "Olivia Beatrice Smith" entered the data, she would choose "OBS" from the "data_entered_by" field.
Is there any reason to keep these codes in Survey123? E.g., having short names and longer labels in my choices sheet in Survey123? Will storing shorter codes make my database take up less size or load faster? Or will it just cause me headaches?
