Is there a way to know if users are connecting to fieldmaps/survey123, etc?
418
04-22-2022 11:55 AM
DanielRivero
New Contributor II
We need for auditing purposes know if users are conecting to Portal using apps like fieldmpas or survey and also if they are using more mobiles, or web, OS is also needed... is there a way to get that somehow?
Best regards,
Daniel R
by Anonymous User
Not applicable
Hi @DanielRivero,
The only way to know if users are connecting to Survey123 is if they are using surveys (downloading them) based on the item view count, or by including pulldata properties in the surveys, which get populated each time they submit a survey. There are properties for device ID, OS, user agent etc, which will give you info about the device and user agent string for the app installed:
https://doc.arcgis.com/en/survey123/desktop/create-surveys/prepopulateanswers.htm#ESRI_SECTION1_D526...
Regards,
Phil.
DanielRivero
New Contributor II
Thanks for your answer @Anonymous User , I have seen it, and it is not a solution for the real problem, we don´t know what devices the users are using to connect to our portal or if they are using the right versions of the apps.  It really could be a security issue.
