Is there a way to have a question defaulted to selected for a cascading select one question, regardless of which option is selected?
722
09-08-2017 08:13 AM
MorganTitus1
Instead of having to specify a specific default value, it would be nice to just have the answer pre-selected.  I only have one option for each cascading select by the way...
Thanks!
JamesTedrick
Esri Esteemed Contributor
Hi Morgan,
We currently don't autopopulate a cascading select when it has only one value.  If you have a situation where there is a 1:1 relationship between the filtering and cascaded values, it might make sense to support this via a pulldata() lookup system rather than a cascading select.
MorganTitus1
Thanks for your quick response.  So with this pulldata () function could you default the answer to always be selected, no matter which look up is used?
JamesTedrick
Hi Morgan,
Based on what you've described, I wouldn't be using a dropdown/autocomplete question, as the selection actually happens on the previous question (if there is only one choice after filtering).  Instead, I would use a text question using pulldata to look up the values - see Formulas—Survey123 for ArcGIS | ArcGIS for more information.
