Is it possible to use select_one and pulldata() together?
24182
40
03-01-2017 10:56 AM
KaceyCummings
I am pre-populating a survey using the pulldata() function and was hoping to use it in conjunction with choice lists (in the event that the native data needs to be updated). It looks like this is not a possibility. In fact, pre-populated fields with type = text will no longer populate when the select_one feature is added to a different field using the pulldata calc.
Any suggestions/workarounds?
by Anonymous User
Not applicable
Hi @KaceyCummings @Pauline_Low_Pui_Ling @DougBrowning @Stephanie_F ,
Just wanted to let you know with the upcoming 3.16 October Release of Survey123 we have extended the pulldata() function to now include spatial searches and URIs (feature service URLs). You can find the latest announcements, documentation and test out the latest 3.16 beta builds via the Early Adopter Community to get early access to these builds.
Regards,
Phil.
