Is it possible to have 2 inputs in the relevant column? If so, how do you format?
629
04-24-2023 08:07 AM
dwold
Can you do something like this in the relevant column:
${name}='value' , ${name}='value'
I need both to be true, not an and/or. I tried using a comma but it does not like that
@ZacharySutherby
@DougBrowning
@IsmaelChivite
Katie_Clark
You say "I need them both to be true, not an and/or", but isn't that what an and statement is? Also, what type of question is ${name}? I don't see how the same question can equal two different values at the same time.
If it was just a typo in your post, and you intended it to refer to two different questions, you would just use the and syntax: ${name1} = 'Value1' and ${name2} = {Value2}
I know you tagged other people in your post and maybe they have a better answer, but hope this helps or can provide additional clarification in the meantime.
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
Best,
Katie
dwold
@Katie_Clark this is exactly what I was looking for. Thank you!
