Is it possible to create a autocomplete textbox from the results of a web service?
2005
07-30-2021 03:30 AM
HalilSiddique
I have just started playing around with Survey123. What i would like to do is allow the user input a postal code within a single text box, that postal code is sent to the web api and all the matching records are then shown within a dropdown menu, which they then select the appropriate address. Is this possible in Survey123 version 3.12?
thanks
Ruth_JiatengXu
Hi @HalilSiddique
Thanks for sharing here! I think you still need version 3.13 to fulfill the functionality. The 3.13 version is currently available on BETA website: https://survey123beta.arcgis.com/.
If you want to search the postal code in your own feature layer, you can use the search appearance:
If you want to search the postal code using a geocoding service, you can see this article for details:
https://earlyadopter.esri.com/project/article/item.html?cap=e69ef91f45744b98882c651f7b518eb7&arttype...
Ruth
AliciaShyu
Hi Ruth,
The links are not working. Could you please update the links?
Alicia
DougBrowning
MVP Esteemed Contributor
If you want easy and want it to work offline you could use a CSV files of zip codes instead.   select_one_from_file with autocomplete would work great here.
