Intermittent Code 503 Errors on Survey Sync
2647
07-01-2019 05:32 AM
DeonLengton
Hi
We have a survey on ArcGIS Online and get intermittent Code 503 errors.
Opening the survey up and retrying sometimes resolves the problem.
The error detail in the log is not very helping:
<15>1 2019-07-01T09:18:59Z DLENGTON-LP Survey123forArcGIS 18360 - [AppStudio@11205 category="qml" function="onFailed" filename="SubmitSurveysPage.qml" line="351"] qml: Feature service error: {
"code": 503,
"details": [],
"message": "An error occurred."
JamesTedrick
Esri Esteemed Contributor
Hi Deon,
Are you still experiencing issues?  It looks like this may have occurred during an issue with hosted feature services documented at ArcGIS Online Health Dashboard
JamesTedrick
Hi Deon,
m3
The irony of these health dashboards is that if something is broken, it's often unable to tell you it's broken.  I've nearly never seen a health dashboard reporting something is down when that thing is indeed down
DeonLengton
Hi James
Its seems fine now - thank you
