Integer fields required by default issue
4099
03-03-2016 08:41 AM
BartoszDerbis1
Since version 1.2.77 all integer fields (xls form type) became required. "input is invalid' message appears if left blank when clicking the check mark for survey completion. I'm attaching the warning message and test xlsx
HannahFerrier
We have identified the issue and have a fix which is currently undergoing certification testing.  This issue is critical and we will issue a special update for the apps as soon as we can.
IsmaelChivite
Esri Notable Contributor
Thanks for your feedback!
An update is now available in the store.
1.2.89: Critical Update to the Survey123 mobile app
