Inputmask in Web Form
2424
09-21-2021 10:39 PM
JulietK
Hi, I saw that the new version of Survey123 (September 2021) supports inputmasks in the web form.
I have an existing survey that was created on Survey123 Connect, template version 3.12. The survey has been published.
I'm wondering how I can update my published survey to the new version, so that I can incorporate the use of inputmasks when the survey is submitted via the web? I would like to still retain the ability to edit the survey in the xlsform via Survey123 Connect.
Any advice/info would be really appreciated, thank you!
Ruth_JiatengXu
Hi @JulietK
Please republish your survey using the latest Survey123 connect (3.13).
Ruth
Ruth_JiatengXu
Hi @JulietK
Ruth
JulietK
Thank you for that 🙂 I got confused as I thought the xlsform version would have had to be changed to the updated version too and wasn't sure how to publish to the same feature service if that was the case
Ruth_JiatengXu
Hi @JulietK ,
After you upgrade your Connect to 3.13. You just need to search for the survey, and publish the survey again. It will be published to the same feature service.
Ruth
