Input mask displays hubErrCheck.inputFormatInvalid in web form
6728
16
10-05-2021 06:26 AM
MikeOnzay
Survey Connect v3.13.234
hubErrCheck.inputFormatInvalid is the error that displayed under the question for a phone number in the web form that uses an input mask. I added label::Español (es) to this question for Phone number. Switching between English or Spanish in the web form displays the same error. This error doesn't appear in the Field app.
In a copy of this survey, that only uses English, this error does not display in the web form
typenamelabel::English (en)hintlabel::Español (es)body::esri:inputMask
textcontact_phonePhone Teléfono(999) 999-9999
RobertAnderson3
MVP Regular Contributor
I just wanted to add my support to the idea of having the constraint message be used when the mask format isn't met, or have the ability to customize the input format not met message.
MikeOnzay
After working with support, ESRI logged this as BUG-000144214, although I'm not finding it in the Technical Support KB.
My work around was to remove the input mask and show it as a hint.
Shwu-jingJeng
Thanks for the salesforce issue#, I will link it to the internal issue.
AaronPaul5
Hi  Shwu-jingJeng,
I'm getting the same error message, both in Spanish and English.
I can't tell if this ended up being a bug or if you found how to fix the issue.
Can you share with me your findings/thoughts?
Thank you,
Aaron
Shwu-jingJeng
Hi Aaron,
This issue has been logged as  this salesforce issue and you may track the issue fix status using this number:
BUG-000144214 Setting an input mask in ArcGIS Survey123 Connect give error "hubErrCheck.inputFormatInvalid"
Ruth_JiatengXu
Hi @MikeOnzay @AaronPaul5 @BrantCarman
The issue mentioned in this post has been fix. If you have any question, please let me know.
Ruth
JThompson_GADNR-WCS
Hello @Ruth_JiatengXu ,
I am using Survey123 connect version 3.25.27, and I am having the "input format not satisfied" notification with my phone number field. I get this whether or not I have it formatted as (###)###-#### or (999)999-9999, and I have corrected the field length.
JThompson_GADNRWCS_1-1785160116160.pngJThompson_GADNRWCS_1-1785160116160.pngJThompson_GADNRWCS_2-1785160152206.pngJThompson_GADNRWCS_2-1785160152206.pngJThompson_GADNRWCS_3-1785160173298.pngJThompson_GADNRWCS_3-1785160173298.png
I guess I could just put the format guidance into the the hint, but I am wondering if there has been a solution to this bug?
Thanks!
