Inlcude an Excel like data table for selecting parcel IDs
614
04-08-2026 05:41 AM
MPach
I'm attempting to make my survey that we are using for development in the city more ADA compliant. It's challenging to say the least. The best suggestion that I've had so far is to create an Excel like data table to present as an option for the visually impaired to take the place of the map portion of the survey. Please see the attached screen shot for the map portion. In this particular case, a data table will work just as well if not better than the map in some aspects because all I need it for is the user selecting a single or multiple parcel ID numbers. Is there a way to include an Excel like data table in my survey? Currently the survey is set up in Experience builder where is hosts the survey on the left and the map that is linked to the survey on the right.
Thank you in advance for any help,
Mark
EdwinCarrillo
You could try creating a dashboard with the form as embedded content and the table as another element that triggers the form when a value from the table is selected. All of this within the experience as embedded content.
AlfredBaldenweck
MVP Frequent Contributor
Alternatively, you could probably use a general dropdown list?
You can pull the choices dynamically from your parcels layer using Dynamic Choice Lists using Search Appearance
Not sure if it's available in web builder, but it could be worth the experiment to publish from Connect to the web.
