Hello. I have a Survey Form which includes Repeats, but not all the data is coming through when Viewing from the Inbox. I have "query allowUpdates" in the bind::esri:parameters field. I am also using calculations and choice filters in my survey. Are the calculations and choice filters blocking data from being viewed in the Inbox?
Hi Suddha
We do have some bugs open that relate to repeats and repeat counts and hope to fix them for 3.1. Can you share your survey and we will use it as a test case?
John
Hi John,
Here is the attached survey form. To replicate the issue I am having, please follow these steps.
Please let me know if you have any additional questions.
Thank you,
Suddha
Hi Jonathan. I just wanted to check in with you to see if there is an update that you can provide regarding my question/issue. I am hoping to resolve this issue in my Survey123 Forms. Thanks!
Hi Suddha
I have done some further investigation and the use of selected() does not seem to be the issue. There seems to be a very specific bug that affects this survey. I have found that removing the top half of the form prevents this issue from happening. So this needs further investigation our side.
I'll raise an issue to look at this.
Cheers
John
Thanks John! I look forward to hearing what you figure out on this.
