Image Annotation - Map and Folder not working
1311
11-16-2022 02:43 PM
MarcoPoetsch
I have an image annotation field in one of my surveys.
While it work fine on the Survey123 Win and Survey123 Connect (Preview), it does not quite work on Android.
When clicking on the image annotation field it opens the camera, however, when I click the return icon so I can choose form a map or from a folder, I get returned to the survey.
I would expect to see this:
I tried different Android devices with all the same behavior.
Is this a bug, a limitation, or something else?
S123 Android version is 3.16.107
S123 Connect version is 3.13.251
S123 Windows version is 3.13.246
DougBrowning
MVP Esteemed Contributor
In latest versions you now need to tell the form which ways to add photos are allowed. This may be what you are seeing.  See this page near the middle  https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformsappearance.htm
Look for method=camera,browse
Hope that helps
DougBrowning
Hope that helps
MarcoPoetsch
aha! Thanks Doug, you provided the right answer (as usual). Much appreciated.
Somehow, I missed that in the release notes.
