Hi, I am trying to get a field to return specified terms depending on the selections in another field.
For example:
Field 'Bird' is a select_one field, and choices are 'Sparrow', 'Pigeon', 'Hawk', 'Duck', 'Eagle'
Field 'Category' is a calculate field, and I would like the field to return the value 'Predator' if 'Hawk' or 'Eagle' are selected in the 'Bird' field, and 'Prey' if neither are selected.
The formula I have is:
if(selected(${Bird},'Hawk'),'Predator','Prey') OR if(selected(${Bird},'Eagle'),'Predator','Prey')
The issue is, the value turning up in the output of the field 'Category' is 'true', REGARDLESS of what is selected in the 'Bird' field.
From what I've been able to find through Google, the formula should be giving me either 'Predator' or 'Prey' depending on the selection choice in 'Bird'.
What do I need to change?
