How to remove a choice from a second list if it has already been selected in the first
1767
03-28-2017 03:41 AM
PeterHeath1
Hello,
I've got two 'select_one' questions in an XLSform and I do not want the answer selected from the first question to be available for the second.
For example if I select
Q1 Sampler Initials?  - Sampler A
1. Sampler A
2. Sampler B
3. Sampler C
Q2 Sampler Partner Initials? (Sampler A disappears because it was selected in Q1)
2. Sampler B
3. Sampler C
Whats the best way to remove the answer chosen in Q1 from Q2?
JamesTedrick
Esri Esteemed Contributor
Hi Peter,
A similar question was asked a little while ago - https://community.esri.com/thread/189993-drop-options-from-single-select-as-they-are-selected  .  At this time, the ability to do this is unsupported; I'm adding this post to request list.
Nicole_Ueberschär
In case someone is stumbling over this question: You can solve this by put for question2 in the choice filter not(selected(${question1},opt)) and column opt in the choices sheet with the same values as in opt. Tested with select_multiple only but don't see why it shouldn't work for select_one questions.
