How to force a refresh calcs for a Nested Repeat
1070
04-01-2020 09:00 AM
DougBrowning
I have a form with a repeat inside of a repeat.  When I advance the outer repeat the inner repeat will not fire any calculations.  Everything goes to blank.
I have tried using once and such but no.
First outer repeat
StationCount is calc of 1
StationNum is calc of once(count(${StationCount}))
Second outer repeat all the 1s are blank.
I then added a if to try and force it to calc.  That works but then adds this Add 4 records box.  But it only does that on every other outer repeat.
StationCount now if(${ThalwegTransect}='A',1,1)
On 2
On 3 the 4 thing goes away
On the 4th the box comes back again.
Ideas to fix this so it fires correctly all the time without the Add records thing?
JamesTedrick
Esri Esteemed Contributor
Hi Doug,
Apologies for the delay.  It looks like there may be something particular to your calculation set - can you provide the XLSForm for those rows?  I've created a test calculation sheet and the calculations appear to perform as I would expect (attached).
