How to Create Inbox Query with DateTime Question?
2050
01-17-2024 07:39 AM
Billy
I'm using Survey123 Connect Version 3.19.104 and the survey is used in the mobile app only.
I want to create an Inbox Query expression using a DateTime question. I tried different date-time formats in the SQL expression with no luck and I haven't found any documentation on how to this. I'm getting "Code 400 Cannot perform query.  Invalid query parameters."
What is the query syntax for this type of questions?
Regards.
YukoYokozawa
My Inbox query expression is thie
CREATED_USER = ${username} AND LAST_EDITED_DATE > CURRENT_DATE - 180
The users can download only their data within 6 months
Billy
Hi YukoYokozawa,
Thanks for the reply. That works but what if I need something more specific like the example in the Survey123 documentation ( Prepare to edit existing survey data—ArcGIS Survey123 | Documentation)
I tried this syntax and got the 400 error. The second image shows the properties of the dateTime field and the syntax that I used.
YukoYokozawa
Does your data show year-month-day? Check your data for the date, my data shows like this
I would try 10/1/2023, if not work, then 10/1/2023 12:00 PM. So try different ways to express your date
Billy
I tried those but didn't work either. But search on the developer's documentation I found the syntax: Query (Feature Service)—ArcGIS REST APIs | ArcGIS Developers
Thanks for your answers.
