how to calculate the week number of a date
1764
09-30-2022 04:37 AM
JavierCMartínezPrieto
I would like to know if it is possible to calculate the number of the week from a date using today() in the calculation field.
I have tried the format-date with the %W operator, but it doesn't work.....
thanks to all of you who participate.
Regards Javier
Javier C. Martinez Prieto
Tags (3)
IsmaelChivite
Esri Notable Contributor
Hi @JavierCMartínezPrieto
If using the mobile app, go with format-date as shown below:
Unfortunately format-date %W is not supported in the web app. If you want this to work in the web app you will need to use a custom JS function. For example:
function ISO8601_week_no(unix_timestamp)
     var dt = new Date(unix_timestamp);
     var tdt = new Date(dt.valueOf());
     var dayn = (dt.getDay() + 6) % 7;
     tdt.setDate(tdt.getDate() - dayn + 3);
     var firstThursday = tdt.valueOf();
     tdt.setMonth(0, 1);
     if (tdt.getDay() !== 4)
      tdt.setMonth(0, 1 + ((4 - tdt.getDay()) + 7) % 7);
     return 1 + Math.ceil((firstThursday - tdt) / 604800000);
If you are not familiar with custom JS functions. Check this blog.
Attaching samples
JohannesLindner
MVP Frequent Contributor
Date Functions | ArcGIS Arcade | ArcGIS Developers
Week(Today())
Have a great day!
Johannes
mikAMD
this is misleading since arcade functions do not work in survey123
IsmaelChivite
     tdt.setMonth(0, 1);
Attaching samples
thank you for answering both of them.
Best regards Javier
