I have a web map containing a hosted feature layer with the pop-up configured to allow field technicians to access a form created in Survey123. The custom URL scheme I have implemented allows the form to pull attributes as well as spatial from the "Master" feature layer. The work flow between Collector and Survey123 seems to work smoothly, however, I want to be able to include the newly surveyed geopoints on the same offline map. When I include both feature layers (Master and Survey123 features) in the creation of the web map it prevents me from downloading the map to the device. Is there a way to view the new features from the survey on the same offline map as the features containing the custom URL allowing you to create them?
