How do other users get enabled to generate reports?
4890
8
01-10-2023 12:19 PM
ChrisYoung2
I have created a report template for survey 123, actually several. It seems that only administrators can use them. What other users can generate reports? I have several creator/publishers and creator/facilitators that I would like to be able to generate these reports. HOW?
Thank you.
Chris
ZacharySutherby
Hello @ChrisYoung2
Checking the share status of the report template will need to be done in ArcGIS Online. The report template should be stored in the surveys folder within the survey owners content. Within the surveys folder you should see the Microsoft Word item and be able to see it's share status:
Thank you,
Zach
IsmaelChivite
Esri Notable Contributor
It is likely that the users have not been granted privileges to request Survey123 reports. Check the role of the user. Under the Premium Content section, make sure that Feature report is enabled as shown below.
ChrisYoung2
Not sure this helps me. We have non-profit licenses and I can't find the page you indicated. As the administrator of the account, I can't find it on the online portal or the organization portal. Perhaps this is not included in the non-profit license.
JenniferAcunto
@IsmaelChivite those permissions are not available in Enterprise. Does that mean that non-admin Enterprise users can no longer create reports for surveys they don't own?
- Jen
ChrisYoung2
Good question! I have no idea. So far it seems that only admin people can process reports. Some threads indicate otherwise though. Trying to find the answer to that question with this one.
ZacharySutherby
Hello @ChrisYoung2 @JenniferAcunto
Users with Creator user types and Publisher roles should be able to create reports. A few considerations is the user will need to have the ability to create content & have the report template shared with them.
Can you please explain a little what your non-administrative users are seeing? Are they seeing the report button greyed out? If the report button is greyed out if they hover over it what is the message returned? It may be possible the report template may not be shared with the user, if that's the case they will need to have the report template shared with them.
Thank you,
Zach
ChrisYoung2
They see everything greyed out and when they hover over it there is a red circle with a slash through it. Where are the share controls for reports? I don't see it on the collaboration page and don't see it on the reports page.
ZacharySutherby
Hello @ChrisYoung2
Thank you,
Zach
ChrisYoung2
Awesome! Thanks Zach! I think that was the problem.
