Hiding multi-part conditional question
1385
07-01-2020 03:33 PM
by Anonymous User
Not applicable
I have a multi-part question based on weather. The first question is a select one, the second question is a multiple selection and the third/fourth questions are select one relate to second question and only appear when "Rain" or "Wind" are selected in question 2. Ideally parts of question 2 "Additional Weather Info." would only appear depending on what was selected in question 1 "Weather." For example if "clear" was selected then only "wind" would appear in question 2 but if anything else in question 1 was selected then everything in question 2 would appear. Any ideas are appreciated.
BenTurrell
Hey Ricky Prowse‌,
Your question sounds a lot like this one: Using choice_filter with a select_multiple question.
There isn't a well defined answer to it but there are some ideas that may help out in there!
Ben
If this answer was helpful please mark it as helpful. If this answer solved your question please mark it as the answer to help others who have the same question.
