Hide qustion in repeat if answerd previously
980
02-15-2018 11:44 AM
BrentKinal1
Is it possible to hide a question in a repeat if it was answered previously in a repeat?
e.g.
Question:
Is this the primary damage causing agent?
() Yes
if "Yes' selected I would like the question not to appear in subsequent repeats.
I wasn't sure if this could be accomplished with a relevant clause or if a repeat_count will work for a single question within a repeat.
Brent
JamesTedrick
Esri Esteemed Contributor
Hi Brent,
Currently there isn't a way to do this, as a repeat cannot effectively look at the values of previous repeat entries.
BrentKinal1
Thanks James, I was hoping I could do it with using the count() function and a relevant but it S123 doesn't like the circular dependency. Maybe in the future the repeat_count field could be set not only for the repeat itself but also for questions within a repeat...just a thought.
