Hi, I need help!
3077
11-03-2015 07:27 AM
YorladyVela2
Hi,  I need help! I recopiled some points,with a survey that had some domains, and these points  were loaded on Arcgis Online. All was Ok, but in this moment the points that were loaded I can´t edit their domains, the domains now appear wrong, instead of  appear yes and no, appear  the label. Besides I can´t create new points in the map.
I republished the survey but it constinues wrong. I thought the survey was the problem it was published how a new map and all is ok, I can edit points and create it.}
what I can do with the information that is on arcgis online?, I can´t edit it
IsmaelChivite
Esri Notable Contributor
Hi Yorlady. We have created a Tech Support Incident for you and will contact you by email.
