Help with calculation syntax Survey123
1942
06-28-2023 11:33 AM
BryceHancock
Hi All,
Seeking assistance with the correct syntax for the following calculation in a survey123 calculate field. I have tried numerous combinations with parentheses but cannot get the calculation work.
(${FIELD_1} div (${FIELD_1} + ${FIELD_2})) div 0.01
FIELD_1 and FIELD_2 are number fields, of course.
BryceHancock
Thanks Ismael,
I realized I had an extra paratheses in the calculate field after I posted. 🙄
IsmaelChivite
Esri Notable Contributor
Can't see any problem with the expression you wrote. It works nicely in both the mobile and web apps. Attaching XLSForm.
BryceHancock
Thanks Ismael,
