Help on adding feature service definition
1188
03-07-2019 12:45 PM
ClancyJandreau
Hello,
I am new to Survey123, still testing and learning how to utilize Survey123 Connect. I have created a form for conducting a trailhead inventory. Each time I try to publish the form, however, I receive the following error: "Unable to add feature service definition." I have checked my xls form and name fields and cannot find any issues. Can anyone help resolve this?
Thanks!
JohnathanHasthorpe
Hi - the issue is caused by the fact you have called your repeat: services. Renaming it to services_ will fix the issue.
ClancyJandreau
That worked. Thank you!
