Header/Footer on/off option missing!
749
7
08-20-2022 08:08 AM
AssociazioneTerras
New Contributor II
The sliders to turn on and off header and footer in a survey are missing in the appearance tab...
JohnPlunkett
Hello
I think that you are looking for the settings here -
It is in the Add + section on the right hand side right at the bottom of the page
AssociazioneTerras
New Contributor II
Hi @JohnPlunkett this is a survey I have created with Survey123 Connect..  I do not have the Add + section....
JohnPlunkett
Hi there
It looks like from your screen grab you have cropped part of the image - are you able to take a screengrab of the whole screen
The Add + button is the first one in that panel
ChiaraCocco
Hi @JohnPlunkett , I hope the below is helpful. Thanks. Chiara
JohnPlunkett
Hello - did you create the survey originally in survey123 connect or the web?
If you created it in Survey123 Connect you will need to make the changes in survey123 connect and make the chagnes there - please review this link about how to style your survey - Style a survey—ArcGIS Survey123 | Documentation
The settings are different to what you can do in the web.
AssociazioneTerras
New Contributor II
Hi @JohnPlunkett thanks for your response. Is there a way to remove the header bar? Title cell is empty in the setting worksheet but I can still see the bar - see the survey first page below (transparency levels cannot be changed)
BrantCarman
@AssociazioneTerras Did you ever figure out how to hide the header/footer now that the options are gone for Forms created in Connect?  I wonder if @JamesTedrick knows a way to do this other than appending "?hide=header,footer" to the survey URL?  I use other parameters in my URL and they don't seem to play nicely with the ?hide=header,footer parameter.
Thanks for any additional info on this!
