Having a layer and geo location for a repeat and an embedded repeat below that.
1217
5
08-08-2024 06:22 PM
STEVEG1223
I want to show locations on map for both a repeat and an embedded repeat below that.
However there is only a table for first repeat with no geo locations on the map. There is a repeat layer for the embedded repeat which has the locations captured.
DougBrowning
MVP Esteemed Contributor
You need to add a geopoint question at each level of the form if you want each of them to be feature classes.  So it sounds like you need 3 total.  Do you have 3?  Posting the form helps a lot.
STEVEG1223
I've attached a view of the repeats in the form. "subcomponent" repeat and embedded "defect" repeat. Also attached is a view of the layers and table in arc gis. The subcomponent geopoints were not captured but the defect geopoints were.
DougBrowning
In the form do you have the Geopoint question in each and every repeat?
STEVEG1223
Yes there is a geopoint question for both repeats. The subcomponent repeat and the defect repeat
DougBrowning
Weird not sure what is up can you post the form or a trimmed version of it?
