Have fields show up for multiple relevant situations
2124
05-22-2023 12:09 PM
MelissaSalich
In S123 connect I'm designing a form where I have a group that will need to have certain questions answered based on the level of survey being conducted.
Level of survey is select_one level, required (level 1, level 2, level 3 are the pick list options)
Condition Rating needs to be filled out for every level of the survey.
How do I formulate the relevant field to show up for multiple select_one questions?
Below is what I've tried but it is not working.
typenamelabelrelevant
begin groupfireFire
select_one yes_nofire_presentFire Protection?
select_one ratingfire_ratingCondition Rating
${fire_present}='yes' and selected(${fca}='level 1' or ${fca}='level 2')
textfire_main_locationLocation of water main${fire_present}='yes' and selected(${fca}='level 2' or ${fca}='level 3')
textfire_commentsComments ${fire_present}='yes'
end group
Katie_Clark
MVP Regular Contributor
what about:
${fire_present}='yes' and (selected(${fca}, 'level 2') or selected(${fca},'level 3'))
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
Since you're combining "and" and "or" statements, seems like you'll need some parentheses in there to make it work properly. Right now the grouping isn't clear.
Best,
Katie
Katie_Clark
Actually, looking again, it could also be because you need to have the word "selected" for both ${fca} parts of the statement.
Best,
Katie
MelissaSalich
I updated the post with the grouping.
I'm still not successful after trying:
${fire_present}='yes' and selected(${fca}='level 2') or selected(${fca}='level 3')
selected(${fire_present}='yes') and selected(${fca}='level 2') or selected(${fca}='level 3')
Katie_Clark
what about:
Best,
Katie
MelissaSalich
this was it! thanks for sharing your knowledge!
