grouping BUG after new update
1373
07-10-2018 12:08 PM
Lake_Worth_BeachAdmin
I noticed after the new update I am unable to select answers on mobile devices that are in groups. (both Android and iOS).
questions types are integers, select one, select multiple... I see the questions and I can open/collapse the group but cannot add answers the the questions in the groups. I could however successfully enter values in the windows survey123 for arcgis app on the desktop client.
can anyone esle replicate this?
I solved the issue by removing the groups in the Survey123 Connect and re-uploading the surveys.
IsmaelChivite
Esri Notable Contributor
Hi. I am not able to replicate this issue. For example, in the attached XLSFile I added questions within a Group and I can work with them normally.
Can you attach your XLSFile so we can see if we can replicate?
I already deleted the grouping and it started working, I went to add the grouping back and upload the excel then it started working as expected.... weird maybe  glitch on my end. case closed I guess, thanks for taking the time to look into it Ismael Chivite
