Grid Theme fields vertically offset
3206
08-26-2021 03:44 PM
MichelleHawks1
I have a simple grid theme survey, using w2.  The first two fields align perfectly, but the second two have a vertical offset in the entry portion.  All 4 fields have w1 in the appearance column,  although 'Ranger Name' is w1 autocomplete.  I've attached a screenshot of the survey as it displays.  Any ideas on how I can get these aligned would be appreciated.
abureaux
MVP Frequent Contributor
I believe they will be addressing this in the next S123 release by aligning all those fields top? I am sure someone else can confirm that though.
Short answer is, there is nothing you can do about that at this time (at least that I am aware of).
abureaux
MichelleHawks1
Thank you.  It's not what I wanted to hear, but is very good to know when to stop banging my head against the wall.  I appreciate your response!
abureaux
@MichelleHawks1Not sure if you follow the beta, but I knew I saw this mentioned somewhere: Improvements to Grid-Theme cell content alignment (select_one and select_multiple choice lists are now top aligned).
This will be added in the next version of S123, which should be soon.
MichelleHawks1
That is good news!  Thanks  🙂
