Grid layout for one group
1292
06-21-2023 04:52 PM
CPG
Hello. I'm trying to give one group in the form a grid layout, while not applying a grid theme to the entire form. I was hoping I could set the column width of one group and subsequently set each question to a desired width. The first and last few questions would be the full width, while all the middle questions would be set to "w1". However, all questions are compressed into a single column width. I thought I read you should be able to achieve this. Due to the complexity of the form, I want to avoid setting the entire layout to a grid. Is this possible?
