I am creating a Survey123 for project logging, and I was wondering if there is a way to set the default map that is used to draw the geoshape. I would ideally have the map be one I can create beforehand that contains our high-res aerial imagery so our users can easily find where to digitize their polygons for the project AOI.
Solved! Go to Solution.
Did you try setting map=<itemID> in the body::esri:style column of the XLSForm (Connect).
