Geopoints wrongly displayed on web map
1356
12-04-2022 09:47 AM
Shubhreet
In my survey, I am collecting data from static locations. I used the pulldata() function to pull the lat/lon of the selected site from a csv file linked to my survey form. The geopoint for the survey is calculated based on the lat/lon pulled but is wrongly displayed on web map. I am not sure what the problem could be. Can anyone please assist me on this issue?
ZenMasterZeke
My first guess would be to check the coordinate system of the map, both in the map feature layer and under the map option in Survey123 Connect (if you're using it) to make sure they match up with your lat/long.
ZenMasterZeke
Shubhreet
Thank you for the response @ZenMasterZeke . Could you please guide me if the coordinate system of feature layer could be changed within ArcGIS Online itself?
ZenMasterZeke
You could take a look at this
