Geopoint location is off when using pulldata from csv
1317
10-01-2024 01:54 PM
RishV-B
I am using .csv to pull data for multiple fields, including geopoint.
The problem is, when I pull lat/long for goepoint, it's plotting the point along the street and not on the building, as the original feature point.
It wouldn't be a problem if I didn't already have a feature with multiple records for each point and they're all geocoded to the correct address buildings.
I found a great post by @IsmaelChivite (https://community.esri.com/t5/arcgis-survey123-blog/pulling-data-from-geopoint-questions/ba-p/896838) about it, but I am not sure how to fit it into what I have with .csv pulldata. If it will help, that is.
Here is what I have in calculation field.
pulldata('FacilityList', 'address', 'name', ${establishment})
pulldata('FacilityList', 'city', 'name', ${establishment})
pulldata('FacilityList', 'zip', 'name', ${establishment})
pulldata('FacilityList','Y', 'name', ${establishment})
pulldata('FacilityList','X', 'name', ${establishment})
concat(number(${lat}),' ', number(${long}))
 Appreciate any suggestion!
RishV-B
Thanks @RoseSimancasM for responding!
It is actually the buildings I needed. I fixed the issue (forgot to update the post).
The issue was in geoprocessing to begin with. I missed the fact that I had the "Preferred Location Type" on "Routing" instead of "Address Location".
Thanks again!
RoseSimancasM
Hello @RishV-B , From my understanding, you are having a problem pulling data from the Geopoint. It seems that every time you want to retrieve data, you’re getting information from a structured location, such as a house or building, but you would like to pull data like the street name instead of the structure data. Could you please confirm this?
The Science of Where
RishV-B
Thanks again!
