Generating Bar Graph
1137
10-31-2022 11:02 AM
KyleBurford
I am new to Survey123 Connect and have run into an issue that I hope someone can help with.
I have a form with 4 select fields. Based on those user selections, I am plugging those values into a series of formulas and displaying the results in a series of tables. No problem.
However, the client wants to also show some of those values in a bar graph. I am unclear how to generate a bar chart based on user selected values within the Survey123 Connect environment. Any suggestions as to how to accomplish this?
Thanks in advance.
Katie_Clark
MVP Regular Contributor
The only way that I think this might be possible would be with a custom add-in...
https://developers.arcgis.com/survey123/guide/
If there is a way to do this "out of the box", I'd love to know!
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
DougBrowning
MVP Esteemed Contributor
Do you mean inside the form?  Can't do that.  You can after on the website though here https://survey123.arcgis.com/  or use Ops Dashboard and you can make all kinds of cool stuff.
