Generate search using the search appearance through a URL via a service that does not store credentials
639
07-24-2024 12:25 PM
Samuel_Colmenarez
I would like to present the following scenario: Using Search Appearance, I want to utilize a URL from a service that does not store credentials. Would it be possible to do this by generating a token from ArcGIS Server? If so, how should it be configured? Or could this be done in another way?
Regards.
@IsmaelChivite
@JamesTedrick
Tags (1)
ZacharySutherby
Hello @Samuel_Colmenarez
It should be possible to use the search() appearance with a publicly shared feature service. Are you seeing an error when trying to use that service?
Thank you,
Zach
