Generate Report: Troubleshooting “An error occurred while generating reports” Error
1906
09-24-2021 08:40 AM
DirkVandervoort
None of the existing geonet posts searching on "An error occurred while generating reports" seem to address the issue I am experiencing.
I have a Survey123 that is long and moderately complex: 400+ line items, a handful of calculations and a handful of relevant calculations. Sorry, I can’t share the template, as it is proprietary.
In survey123.arcgis.com, I select the survey, select the “Data”, generate a sample template (successful), then generate a sample report
At the end of the process I get an error :
 with no other information.
When I attempt to Generate a report
. After attempting to generate the report I get the
 error with no other information.
When I click on the “Show details” link I see this:
Clicking “More details” shows this:
If I remove all fields from the report template, it successfully creates the report.
If I leave just one field in the report template, it fails to successfully create the report with the error:
Questions:
  • How do I troubleshoot this, especially for such a long survey?
  • Any idea what’s causing this issue and how to resolve it?
TIA
JamesTedrick
Esri Esteemed Contributor
Hi @DirkVandervoort ,
If you haven't yet, it would be helpful to open an Esri Support ticket; Esri Support can help you troubleshoot the issue.
- Sharing the form's XLSX and report DOCX would be helpful in attempting to replicate the issue.
- Is the error appearing for any feature, or one specific feature?
