Format time calculation with hours and minutes
7932
12
11-09-2017 07:58 AM
bshepard
Is there an easy way to calculate a duration from start to end displayed in hours and minutes?  I've only seen mention of either/or. I've tried a few things unsuccessfully.  Essentially I just want ${EndTime} - ${StartTime} in a h:mm format.  So, if I have StartTime = 12:00PM and EndTime = 2:06PM, I want Duration to be 2:06, not 2.1 hours or 126 minutes.
Tags (3)
khalilramadeen
Hello James Tedrick
Is it possible to calculate the hours and minutes for more than 24 hours. I tried the excel sheet you've attached here, but when fill for example (2:47 PM as start and 12:32 AM as end) this will give a minus value. I wanted to know if it's possible to get values more than 24 like 50:45 as summation.
Thanks in advance,
Khalil
JamesTedrick
Esri Esteemed Contributor
Hi Khalil,
You would need to use datetime question to get the appropriate value, they should automatically account for the extra days.
ChrisRoberts2
This was just what I was looking for!  Thanks James!
Just one question how do I get it to calculate part hours eg 1.5?  this just seems to give the answer in whole hours
