Format for iPad
2030
09-27-2016 07:40 AM
RobertParsons
Hello,
Is there a way to format the surveys for an iPad?  Or is there a way to format groups side by side instead of scrolling from top to bottom. Or, another way to ask, Is there a way to maximize the use of the screen real estate of an ipad for surveys.
Rob Parsons
Tags (3)
DerekLaw
Esri Esteemed Contributor
Hi Robert,
Using the Survey123 App on iPads works the same as on iPhones. There is nothing different.
This is currently not possible. Please submit an enhancement on the ArcGIS Ideas site, ArcGIS Ideas
Please take a look at some of the appearance options to format survey questions. Especially the select_one and select_multiple questions. Some of these options may help you optimize the larger screens provided by iPads.
Appearance—Survey123 for ArcGIS | ArcGIS
Hope this helps,
DerekLaw
Hi Robert,
Hope this helps,
RobertParsons
Derek thank you for your insight. I will make that idea request.
Rob
