format-date issue in web form
1334
04-27-2022 04:23 PM
ChrisRoberts2
Hi All
I have created a form in survey123 connect and as part of that I create a unique ID which is a concat of the user ID and the current date and time:
concat(${observername},"_",format-date(once(now()), '%y%m%d%H%M%S'))
This works fine in the Survey123 app eg 9359_220427140725
However if I use the webform (desktop browser) I get this result: 9359_Invalid Date
Does anyone have any suggestions?
Cheers, Chris
IsmaelChivite
Esri Notable Contributor
once would generally be used like this:
once(concat(${observername},"_",format-date(now(), '%y%m%d%H%M%S')))
However, it is not guaranteed that ${observername} has a value when the form is loaded. You may want to consider using
IsmaelChivite
ChrisRoberts2
Thanks for the rapid response Ismael!
You are right that with once the observer id wasnt populating.  However the second option works...although I had to add another close bracket at the end 🙂
