Fields by default
1509
01-20-2021 11:39 PM
juan_luisGarcia_González
Hola,
¿Cómo puedo elegir campos de forma predeterminada en el sitio web de Survey123? Cuando abro la "tabla de atributos", solo puedo ver ObjectID por defecto.
Gracias.
Tags (1)
ZacharySutherby
Hello @juan_luisGarcia_González
If you navigate to the item details page of the feature service associated with the survey, go to the Visualization tab, select Configure Pop-up's, then Configure Attributes, do all the fields that you would like displayed have a check box under the Display column?
Thank you,
Zach
Thank you,
Zach
