When using the repeat_count column, why is there a field (<repeat_name>_count) automatically created in the schema?
I would like to remove this field from my geodatabase.
Olivier
Hi Olivier,
The _count field is being generated by the form conversion process. It should be addressed in the next release of Survey123.
Hi Olivier,
