Feature Report polygon color
721
06-02-2025 08:57 AM
KyleKeath
Hello all,
This has been discussed before, but I am not quite getting the outcome I need. I have a geoshape question in my Survey where a user will distinguish a general flight path for a UAV. I need the feature report pdf to display a certain color of that flight path area.
I have no issue in the XLS form to use in Connect, but when launched in the Survey 123 web app the drawing is still the blue outline and transparent fill. It is produced with the same colors in the feature report pdf as well.  I'm using drawingInfo: "currentLayer" in the word template. I have also used mapSettings code in the word template. It pulls in the web map, with previous submittals in the desired symbology, but the current feature still blue.
thanks GISers
MicahPaulkHG
I’m not certain if this the correct way but I brought the layer from Survey123 into Pro exported the features to a new layer. Changed the symbology to what I wanted. Shared that as a web layer from pro then used the “drawinginfo” syntax in the report with the new web layer url.
see ya on Monday
MicahPaulkHG
see ya on Monday
