Fail to save changes in Collaborate settings
1710
01-31-2022 01:34 PM
AliciaShyu
I'm trying to change the setting to where submitters can "Only add new records" but I'm getting the following error.
I believe is because the URL is wrong, it has  ADMIN in between rest/services/(folder name)/(service name). Where can I go to update the URL?
The survey was created using Survey 123 Connect 3.13.251Survey123Error.JPGSurvey123Error.JPG
AliciaShyu
The survey works, I'm just changing the default "Add, update and delete records" to "Only add new records". I get the error when trying to save this new setting.
I think I found a work around. In Survey 123 Connect under "Options", I disabled "Enable Sent Folder" option and that solves my problem of editing and deleting surveys.
by Anonymous User
Not applicable
Hi @AliciaShyu,
Is this a new error, did the same survey work previously? Did you change anything recently or publish with a new version? You should not need to change the URL, it is created based on the portalURL appended to the survey123 website URL when you enter the portal or use a link that creates it.
Phil.
AliciaShyu
